Here is a list of the big work I've had done on the LR3 covered under warranty (GMAC)
Purchased 8/08 at 55,101 miles
First visit to dealer 10/10/08 at 57,267 miles
1. Clogged drains - Labor $172.50
2. Keyless entry inoperable - water intrusion from clogges drains damaged splice. Installed new link of wire and covered in shrink wrap. Remolded harness and sodered jumper wire --- Labor $172.50 Parts - $8.08
3. Steering rack and pinion replace - Labor $230 Parts-- $491.40
4. four wheel alignment per steering rack install $79.95
5. Replace power steering pump - Labor $149.50 Parts -$313.77
6. Replace air cond. compressor - Labor $529 Parts $548.09
7.Replace Air suspension compressor - Labor $161.00 Parts $665.93
8. EAS system calibration $92.00
Total bill including some out of pocket expenses (Oil change and deductible)
$3692.55 (out of pocket expenses were about $400)
Second trip to dealer - 2/15/10
1. Replace control arm bushings - $285.02
2. Install new parking brake wiring harness -$269.00
3. Replace coolant resevoir --Labor $99.48 Parts. 74.53
4. Replace power steering pump (again) Labor $223.83 Parts - $333.76
5. Replace ball joints and tie rod ends - Labor $99.48 Parts. $220
6. Replace leaking washer fluid resevior - Labor $298.44 Parts $97.56
Out of pocket expenses included -
1. 90k mile service $513.85
2.Air filter- $36.78
3. mount and balance customer tires $120.00
4. Replace transfer case fluid $118.26
5. new battery $235.28
and other misc. stuff
Total $3357.41 (out of pocket $1585.22)
Total $7049.96 not including PM and oil changes and the like.
