Air release when opening doors normal?
Mainlander
Canada
Hi Everyone, just picked up a 2010 recently and loving it. Still getting used to all the complexities of the vehicle. So my question is, it seems everyone once after it's been sitting for a while, and I go and open a door, I hear a quick hiss (i.e. air release). Is this normal?
Your suspension is adjusting itself.
Mainlander
Canada
Okay thanks. I just thought it was weird that it seemed to happen more when I opened the door.
toddjb122
My LR3 always did that and my LR4 does as well. It periodically makes this adjustment, but seems to always do a check when you're getting ready to go.
Ben Myton
Tacoma WA
Quick follow-up on this, my 13 LR4 also occasionally adjusts on me which is disconcerting. After being stopped for a period of time (stop lights works, exiting car too) it will lower slightly. It's particularly odd sitting at a stoplight and then having the corner shift on you.
Is the adjustment the result of an out of calibration system, or does the controller not constantly check the height so it just periodically has to adjust for chainging air temperature/pressure?
morrisdl
I think the bigger "hiss" he is referring to is the release of galley pressure associated with the compressor shutoff. This would happen every time you shut off the truck while the air compressor is also running. This release allows the compressor to restart more easily next time. The shorter "pist" leveling adjustments only happen after all the doors are closed.
DenverLR4
Air suspension adjusts to keep ride level. If you unload significant weight from truck, or detach a trailer, you'll see it re-level vehicle by bleeding air off.
Austin G
Sandy Eggo, CA
I notice the adjustment quite often in fast food drive-thrus. I thought my LR4 was making a judgment about my eating habits, but realized it's because many drive-thrus have uneven paving and weird angles with sharp turns.
Disco2TrailEdit4
