anyone else have rear windows that don't work?
deeb
have you seen this?!?!?
http://www.roverparts.com/Parts/AMR1282RK.cfm?bc=ab
my rear windows did't work so i was looking around for a new window ecu and found this.
if you click on the 'instructions' tab it tells you exactly what to do with it. i just used a length of wire with a couple connectors and bingo, rear windows work!
That is one way to fix it.. the other is to remove the window ECU and just re-solder the offending bad joint.
greg409
I did the resolder last year & it worked great
I have never seen the jumper wire offered by A.B., can't see how it would help if your board was cracked or a soldier joint has failed.
