I,ve had problems with rich fuel, engine dieing, rough running and my 96 disco running like junk. Last night we hooked it up to an obd2 and scanned for codes. the coes I got back were in order of
1. p0118 engine coolant temp circuit high input
2. p0125 closed loop fuel ctrl insufficient coolant temp
3. p0113 IAT snsor 1 circuit high input
4. p0183 fuel temperature sensor A circuit high input
5. p0340 camshaft position sensor A bank 1 circuit malfunction
6. p1607 manufacturers control auxliary inputs auxilary outputs
7. p0103 maf or vaf circuit high input
My freind who is a mechanic though he is not real familiar with land rovers got on to the all data diy and we found wiring diagrams for the truck from looking at those we've kind of concluded that all the bad sensor errors were coming off of one circuit the wiring diagrams that circuit is labeled as s150 on the diagram. my guess is its either this wire is shorted out or the ecu is bad. If it's not the wire and the ecu is bad can I just purchase a new one and install it in my truck or does it need to be reprogrammed for my truck ? and if anyone knows anything about this wiring and or the error codes any info would be greatly appreciated!
