Coolant
Canvasback13
My 2010 range rover hse is low on coolant. The manual states i should use Havoline xlc or Wss-M97B44-Orange
Can I use prestone Dex Cool extended life orange.? I cant find The Havoline XLC.
The dex cool says it is WSS_M97B44-D.
I now realize there are different varities of WSS-M97B44. There is at least an A, B, and D variety. Will this D variety be ok?
Any thoughts? I know dex cool doesn't have the greatest reputation, but is this the correct coolant for my RR that meets the specs?
Thanks
socalrovershop
just add water. there will be no harm done. you wanna start mixing half and half or depending on what kind of climate your in when you start replacing mass amounts of coolant. if its slightly low then just add water. If your lights on then find out why its low possible leak
tango90
