Door Lock (latch) Actuator
05LR3
The driver's side rear door on my 05 LR3 takes at least two to three pushes of the remote before it will lock or unlock. Also, when the vehicle is shut off and the key removed from the ignition this door will not unlock and when the vehicle is put in gear and in motion all doors lock except this door. Is my lock (latch) actuator going bad or could this be solved by lubricant in the right place? Does anyone have any experience with this problem? If the actuator needs replaced, how difficult is the labor?
