Engine Code P0101 MAF?
dry_fly
Been getting intermittent "reduced engine performance" message, it goes away but then comes back. usually low RPM's around 20-40 MPH. My 05 V8 threw this code P0101 which was read the following MAF OR VAF A CKT RANGE/PERF. I would assume this is Mass Air Flow, however I haven't seen anything regarding this code. Found link to Rangie forum http://forums.landroverworld.org/showthread.php?t=15926&highlight=p0101 but it wasn't too helpful.
Anyone seen this on your LR3?
Found link on LRRForum that it could be Throttle Body, but not able to find those online.
http://www.lrrforums.com/showthread.php?t=6200&highlight=Mass&page=6
If it is Throttle Body how involved is the DYI if I can find the parts?
Appreciate guidance.
Grazi!
The 101 is a fault code indicating your MAF circuit is out of range/performance.
Time for a new one. By the way, how often do you change your air filter, are you using paper or a K&N type filter.
When buying a replacement do not buy after market or generic but buy one with matching part numbers.
dry_fly
Thanks Mike, I'm hoping it's the MAF & not the Throttle Body I heard of on the other forum. I'm due for a new Air Filter. so I'll order that up too. Matching numbers I assume you're referring to LR OEM vs. 3rd party for the MAF & Filter?
Cheers,
Charles
Just make sure it has the same model number on the replacement as your original one has and go with the factory air filter, it is a lot better then an after market one from the parts store.
Disco2TrailEdit4
