Simple rules of engaging low range, and Terrain response passed on to me from a Land Rover instructor, and long time adventurist/explorer
- Never engage low range while the vehicle is moving in any modern Land Rover. The LR4 (as well as most modern vehicles) use an electric solenoid to engage low range, and in the LR4 the solenoid will not /Should not engage about 2.5mph. Because of the action happening on a set of dogs and syncro gears, which will find home (if they haven't already), once the vehicle is moving again (hence the flashing light, till it's engaged fully). On "shifted" style transfer cases you are actually meshing the gears so you needed some momentum to help with the engagement.
- Always plan ahead. If you are in a situation where low range will be needed or thought to be needed, engage it prior to reaching said situation
It make no sense to engage it, once it is already needed. Once forward momentum is stopped, chances of "suddenly" engaging low range and pulling through are very slim. Same applies to TR. Select the appropriate mode for the environment.
- I have been off roading with guys who only engage low range once it is needed, needless to say it was a long day pulling/pushing guys through. Unless I am in between obstacles or resting, low range is always engaged.
