LR3 Add CarPlay without removing radio
wheeler
@Nelz99 yes, the included backup camera implementation is fantastic. When the vehicle is in reverse, any streaming audio pauses and the entire screen instantly shows the camera image full frame. The image quality is much better than the (wireless) Garmin BC-30 I had been using for years.
@WestHamPaul This unit comes with a fairly decent, adjustable suction cup mount. To start, I used this factory mount suction cupped to the factory nav screen, which I do not use. In my experience, all the suction cup mounts I have used have eventually failed- and at the worst times. I have used hair dryer heat to try to recondition the suction cups and isopropyl alcohol to assure a clean bond but still have had problems with reliability.
It's unconventional but I decided to temporarily remove the Land Rover factory rubber tray mat and screw down a proper pad mount. I used an Arkon heavy duty drill base mount. If I change my mind, I can fill the two holes and put the rubber tray mat back.
It's interesting, the Road Top 7" screen itself is almost a perfect fit to sit right on top of the factory nav screen- it fits right in - except for the protrusion of the connecting cables on the left side. The connecting cables are (ignition switched) 12 volt power, 3.5mm stereo out to LR AUX in, and the included rearview camera input. But in day to day use, I don't like the display tilted back- I prefer a stable, vertical orientation.
Hazer
Minnesota
Looking to add a 7" screen where the factory nav usually is in my 2008 LR3 SE. It didn't have factory nav screen. Compared to previous posts, my wiring is a bit different. Can anyone tell me where I should tap the factory plug (what wire or pin location) to get power to the new 7" car play unit? See the attached pic.
Also, can someone confirm which wires are the correct aux wires to tap into? Again, my wiring is a bit different so I don't have blue and red. See the pic of the small plug...I think it would be pin location 7,8 and 6 for ground.
Martin Isaac
raleigh nc
These are the speaker level out from the factory amp. I wired directly from my afternarket HU to an amp, then out from the amp to the speaker level outs. Sounds great.
NC
@Hazer did you ever receive any clarification or response to your question here? I have a 2008 LR3 SE (no NAV) and am looking to do the same as you are here.
Nelz99
NW IL
I installed this android unit recently which uses google maps or other gps navigation you can download from google play plus Android auto using the usb connectivity as well as wifi hotspot from my phone. I can play Iheart Radio or other streaming service while connected to hotspot. It also has built in radio but still use factory harman kardon radio. I connected it to the aux input of the gfactory unit so I retain the use of all steering wheel controls, CD changer, etc.
Did this stereo have aux out? I’m trying to connect mine to the existing Bluetooth aux in already installed on my LR3
