LR3 wanders with 7 passengers - need diagnosis help
km7648
I have a 2006 LR3 (base) with 100k miles on it.
It wanders on the freeway and tends to follow ruts etc. With 7 passengers, the wander is dangerous - it feels very top-heavy and oversteers.
About 10k ago, I replaced the front A-arm bushings and the tires. Today, I checked all suspension components for obvious wear, broken fasteners etc. Everything looks good.
I don't mind spending some $'s to get the right parts but would appreciate any feedback as to the most common problems...:albertein
good call on the alignment....but it's worth noting that my LR3 has ALWAYS followed the ruts; it's called "tramlining" and it's not uncommon.
km7648
Have you had the alignment checked?
It was done about a year ago but I'm going to run it in have have it re-checked. No noticeable wear but I know that isn't always reliable.
Thanks
joecool509
When mine is loaded down (KLR motorcycle hanging off the tail) and filled with stuff for vacation she would kick in and out of ruts.
Quijote
Metro Boston
Exactly. And typically more prevalent on low-profile, wide tires.
tlt
That is also a symptom of worn bushings, worn out dampers may also contribute to the problem.
Anti Roll Bar Bushes
Front Upper / Lower (real common) front bushings (change the entire suspension arm)
Rear bushings also wear out, easier to change out the entire arm.
sure but that's easy enough to check for....
GeoRover
Speaking of which, I need to change my car's front Anti Roll Bar Bushes too. Got the rear ones done a year ago. Something I can do or a shop you recommend for the right price? Maybe want to have the Control Arm bushings looked at also.
Hi locals, I am still here ;)
I remember Land Rover Seattle doing mine for a fairly cheap price...
Vintage99
