Lrd2 Starting Problem
bsa239
Recently had the Cramshaft sensor replaced as there was no spark and no gas, now have spark but it appears no gas to fire on. All fuses and relays appear to be good. Did buy the shop manual which arrived about a week ago. Any ideas?? Mike in S. IL USA
Check the relay for the fuel pump and also check to make sure you fuel pump even works... How many miles?
Could be a bad fuel pump or bad relay... I would start with the relay. Keep in mind that sadly the D2 does not have a true fuel filter like the D1 so and crap in the tank will clog the pump easily.
bsa239
Shaggy;
Got your test, my LRD2 is being worked on today, hopefully it will be running by the time I get home from work. Really miss driving it.
Mike
bsa239
testBook
Need a little help, once a new Camshaft Sensor is installed, does it have to be set to talk with the computer, my son the Mechanic says there is a device that we need to do this.
Something called a testBook. I found the testBook manual but am wondering about the device.
Mike
bsa239
Nico3dd
