Brillo Pad
- Joined
- Jan 2, 2008
- Posts
- 14
- Reaction score
- 0
(2001 Disco II)
A while ago I posted a thread about a problem I was having with some codes and a service engine light - and with this forum's help was able to track the issue down to the mass airflow sensor. I ordered a new sensor online and easily swapped out the old one. Sure enough after a couple restarts and miles the service engine light turned off.
However, all was not well. With the new MAF sensor, I gained a new problem. From a standstill there developed a pretty big delay from the time I put my foot on the gas to the time I received any real acceleration - to the point of being too dangerous to attempt to pull out into steady traffic. To be on the safe side I put the old MAF sensor back in. The service engine light came back on, but the power delay issue disappeared.
I called my closest Land Rover dealer (90 miles away) and they said most likely the system needs to be reset and I should be able to get this done with a generic code reader at any autozone. I put the new sensor back in and gave this a shot but it still didn't fix the issue.
As a last ditch attempt I'm going to leave the negative battery terminal unplugged over night to hopefull completely reset the computer, but I'm really just grasping at straws now.
Any body have any idea why I might be having this problem and how I might be able to solve it?
Thanks very much,
- Mike
Thanks very much,
- Mike
