No Horn on '98 Disco
tking24854
I had an issue where my key got stuck in the ignition. After work was done to fix the problem, which included getting into the steering column, the horn doesn't work. I didn't realize this until over a month later. The horn does work as the alarm sounder. Is there a connection I should be looking at?
I can't call the mechanic because he'll deny touching anything with the horn and then charge to troubleshoot.
Any ideas?
Tim
You need to test and see if you are getting any voltage down to the when from your horn button.
Do you have an OHM meter?
tking24854
Thanks for the reply. I haven't checked voltage yet. Is there a connector or something the mechanics forgot to reattach when working around the ignition area?
Should be one under the steering wheel that in turn goes down the column.
Dandavies9
