Range Rover 3.0 TD6 Automatic gearbox problem
rado
Viro
The car doesn't go anywhere.
Not forwards or backwards.
Although put D or R.
If you try to push or tow a car forward but backward.
Where's the problem ?
What year RR and What exactly does it do? Are you sure it is going into gear?
rado
Viro
2004 and not forward or backward.
Just push forward. Backward if you try to push so all the wheels are stuck, ie do not move backwards
I would check the linkage and make sure the transmission is even going in gear.
33CHINACARS
Don't want to scare you but it could be a bit more serious . Common fault. The metal in the Hydraulic cylinder is soft & wears . As it wears you loose pressure to the clutch plates . Particularly the ones in the torque converter . Clutch material then goes through the cylinder & creates more wear. A never ending circle. The transmission is a GM 5L40E . I've had mine rebuilt with some stronger parts. Not cheap though. IIRC it cost me about AU$ 7500
rado
Viro
Mikä osa on eniten katkennut, kun ensimmäinen katoaa R ja sitten D?
Turbiinin / vääntömomentin muunnin tai mitä?
Sadly we do not read or write Finnish very well:
Which part is most broken when the first disappears R and then D? Turbine / Torque Converter or What?
Vintage99
