Ticking nose or just ticking bomb?
Jermgallo
Lowell,ar
I have a 2011 LR4 5.0, Since the change in weather I have been hearing a ticking nose on cold starts in the morning. Once I start rolling the nose goes away and doesn’t come back until the next cold morning. I had my mechanic listen to this video and he was unsure. He wants to start with the pulleys to see if the issue is there, if not the other idea was a bearing going out on the alternator. Any thoughts or ideas would be greatly appreciated. Let me know if link isn’t working.
PaulLR3
Boston
The LR4 is a noisy engine even when new so it's hard to diagnose issues over the loud fuel injectors.
I will tell you that if your alternator is making that noise, the valve cover gasket above it may be leaking and dripping oil into the alternator. That happened on my LR4.
Cthehentz
Las Vegas
It is not timing chain noise. I believe that has something to do with viscous fan clutch. Type LR4 and clock into google and you should pull up similar videos.
Yep cooling fan, my LR3 made this same exact sound and it was the fan.
Jermgallo
Lowell,ar
I checked after driving for a long while and I can’t see any oil leaking from anywhere
PaulLR3
Boston
Yes! This is it. I had my fan replaced and the noise was similar.
Cthehentz
Las Vegas
so you just replaced the fan only and it stopped with the noise?
The click was coming from the fan assembly so I replaced it. The same exact sound yours is making and at first I thought it was a timing guide slapping.
9ineballer
