Transmission problem
BENTLEY
Hello,
may I present myself ? I'm driving a Range 1994, living in Belgium, near the city Ghent.
Till today I,had no problems with my Range, but this morning the transmission stayed in neutral. Even when I go to driving position, nothing is working. The car does start and all the controll lamps are working, but the computerpanel indicates " electrical defect transmission " . I did a check of all the fuels and nothing seemed wrong.
Is there anyone with comparable experiences ?
Bentley
I am hoping someone on here has had a similar issue, if not I will make a few phone calls and see what I can find out for you.
BENTLEY
Electical Transmission Problem
Thank you very much Joey !
I am looking forward for any reply. :help:
Yours sinceraly,
Bentley
petty
Have you check if your fluid level is correct? Its important to check for at least even twice a year. If it seems your losing fluid then probably you have a leak. Also check if your filter is clogged.
___________________
Autopartswarehouse.com Car Mods.
