T
TehSparrow
I drive a UK LR Defender 90 SWB, and it has a bad oil leak that i think has turned terminal.
Driving to school today, I noticed that the exhaust fumes were very black and the cab was smelling of burning oil. When i stopped at school, there were large deposits of oil on the back of the landy from the exhaust, and when i opened the bonnet i nearly cried. =[
The entire left side of my engine was covered in oil, pouring out over everything, and going everywhere. I let the engine cool, & checked the dipstick, but the whole contents of the sump was sitting in the car park.
I managed to fill the car up with some oil and limp home, but now I am stuck without a car to use! When looking at the engine running while at home, i noticed that there was alot of pressure being released from the dipstick, and when i took the breather pipe off, my beautifal Landy resembled a steam train.
I've read through some books, and I wondered could this be the head gasket gone? there is a shed load of pressure building up in the engine, which is forcing out all this oil (seriously, every bolt hole, seal or gap has oil leaking from it!) and now leaving via the exhaust system.
If not the head gasket, can you suggest any other reason for my baby to suddenly go bad? Also, can anybody give me any indications / websites that detail how to fix a head gasket (or the actual problem) as i will be doing the work myself if possible.
Will i need to remove the engine? I have heard that it can be possible to "top & tail" an engine & remove individual pistons to replace the broken component, but i really would like some advice from a few Landy Vets. first!
Thankyou for your help!
Sparrow
Sparrow
