warning light problems
Grandis
I replaced my battery and now every warning light under the sun is up. The temp and fuel gages do not work Any Ideas on a fix? Thanks:albertein
More info:
Year of RR
Is the new battery fully charged?
Why did you change the old battery?
Any chance the alternator is having issues?
Grandis
1997 RR 4.6 HSE,
New battery, replaced because the old one died while sitting for a while.
You say it is a new battery, but it is fully charged? I know normally they are, but a less than fully charged battery will cause the issues you are having.
roverboy3766
i am having the exact same problems
hey will you read my post. i am having the same problems. my gauges, speedometer and everywarning light is lit up. i drive a 96 range rover 4.0 se. if you get yours fixed. tell me what you did. also post me back when you get this and give me more info.
Grandis
still problem
I deffinately did not reverse the connections. RR dealer told to disconnect the negative wire for 15 min. But it did not work.
dimitricourmousis
