LH low beam is out
B
bluerover2002
Everytime I replace the fuse it blows instantly, and the high beams work. ANy suggestions? THanks in advance..
B
bluerover2002
its not the bulb though if the high beams work or am i wrong??
Slartibartfast
there are two bulbs, the main headlight and a tiny little bulb that sits in the same unit and kinda does the job of the parking lights not sure about the fuse blowing though
K
krazz1e
Not sure your year, but my '96 the wires were very worn and actually started to disconnect from the plastic. Take a close look at the connecters and see if this is the problem, could be shorting therefore blowing the fuse.
B
bluerover2002
This is crazy but i wiggle the headlight a little and it comes back on. It goes out sometimes but a little tap wiggle wiggle tap it its back in business! I should be a mechanic lol! Thanks for all the replies
STQAddie91
