davez26
- Joined
- Dec 15, 2005
- Posts
- 357
- Reaction score
- 2
Installed the 265/65/18 BFGoodrich All-Terrains this week. Looks pretty good. Doing the math, they are only 2 millimeters taller than the 285/60/18 Nathan and others have been running. I went with these, because the BFG seems to have a gnarlier tread, the width is about 3/4 inch narrower, for a litttle more dig and bite through the snow we face around here, and honestly, I've used BFG before and just have a pile of faith in them. They've taken me through everything back when I had my FS Cherokee. Anyway, now you have even more choices in the big tire department.
How does it go? I've lost a little snap out of the throttle, which is to be expected. Stopping takes a little more too. Remember, you are adding about 20# per wheel additional rotating mass to the braking system, but it isn't anything huge, just a change. Clearance is not a problem at all in the front, and the rear rubs on a little bump in the front of the wheel opening about halfway cross the tread. But just a little bit, and only when making a hard-core quick turn that leans the body into it. I suppose that it would rub that driving in access over bumps too. No problem, that shield is open @ the bottom, so anything that gets in there will leave anyway. I may hit it w/a heat gun to see if I can warp it inward. The thing that really suprised me is the the ride and handling. The ride is stiffer, and part of that is tire pressures, but steering response tightened up. Those Goodyears were like driving in slush compared to this. I reckon it is due to the stiffness in the 3-Ply sidewall. I can detect just a little road noise, but nothing huge. All in all, I'm pretty satisfied. Well, except I'm stuck to the house this weekend and can't take them out. Damn!
I posted a picture in the gallery too.
