Here are a couple of closeups of the control switch location, which for me was the hardest part of the installation process since you need to be very precise when drilling for the switch to be secure. The instructions accompanying the kit will tell you exactly what size drill bits to use (in millimeters, I'm afraid... This kit is from Australia) and how far from each other the 3 holes need to be, but doesn't indicate a suitable location for the LR4, only the LR3. So, hopefully the photo helps you in picking the right spot in your car. As I mentioned earlier in the thread, I couldn't come up with a better one.
In the first shot, I removed the knob to show you more or less where I drilled the 3 holes for switch, LED and centering peg on the RH side of the steering column's lower cover. Don't drill much lower as you may get in the way of the emergency start sensor that's laying on the inner bottom of the cover. The second photo shows the same switch, with knob in place. You will likely get the fancier knob that more closely matches the look of the remaining knobs on the dash of the LR4, you lucky dog. However, the 4-position switch (-20mm, 0mm, +30mm, +50mm) behind the knob should be the same.
The last shot shows where I mounted the "emergency" button that allows you to access useful additional features implemented in recent firmware releases (recovery mode, aka +100mm, extra low mode, aka -50mm, locked mode, fade-out mode). I found the rubber boot under the steering column, behind the square opening at the top of the kick panel, to be ideal for that as there is no chance of pushing that red button accidentally while driving, but it's still accessible by feel from the driver's seat in necessary. Just drill a small pilot hole in the rubber and push the switch through.
And, in case you did not receive the link yet, this is the online installation and calibration + user manual: https://www.box.com/s/46ezof3vcgc9zvo2i9do - Graeme may have already loaded default values for your LR4 in the module you are receiving, so there may be no need to go through calibration, but it's a 5-minute procedure anyway, so no big deal.
Good luck with the install, you will find this mod to be one of the most useful for this vehicle, especially if you plan on wheeling it. Also, when traveling I usually set the suspensions at the -20mm setting, as I find stability of the LR4 in turns to improve a lot when it is just a tad lower than normal height. Try it out!
