LR3 jack?
I put it in my homemade drawer system.
You are obviously handy with the tools. You should consider regaining all that used up space with those drawers (nice looking though) and build into the cargo floor a hatch system for all that junk not often needed.
I fit as much or more than those drawers would hold all below the level of the cargo mat but have not yet built the hatch-floor in my mind.
do you have instructions for installing the rear light guards?
I do somewhere if it's the aluminum ones you speak of. The plastic ones look really simple though. The aluminum ones are a little annoying to install properly. How do you not have the instructions if you have the kit?
I use the scissor jack too for now. It's been fine, I have some big jack stands I use when I do need to lift her.
Funny thing though last night I was removing the lugs off the wheels and the LR lug wrench sheared apart.
That's another tool to out away somewhere and replace with a 24" breaker bar and deep 6 point socket. You should also be using a torque wrench. 105 lb ft I think.
Silmarillion
I bought them used from someone that just sold his LR3 Dino.
Aluminum. It's got 2 brackets with it also.
Yeah, you're going to need the instructions because there are some little tiny spacers that need to go in the right order.
