Morimoto fog lights on my 2012 LR4
Georgemera1
I installed myself these fog lights, bought it from The Retrofit Source they are plug and play. I like them.
jeffdude
Are they brighter than stock or did your LR4 not come with the lamps??
PaulLR3
Boston
I prefer my yellow fog light bulbs, since I only use the fog lights in heavy fog or snow. I can even turn off the headlights to avoid blinding myself as the headlights reflect off the oncoming snow.
Georgemera1
My LR4 is HSE Lux so it came with fog lights but they are halogens with the light little yellowish.
1st. I replaced the bulbs with the new 2x Philips H11 CrystalVision Ultra Headlight Bulb, but they were not enough white comparing to the Land rover signature LED lights and finally found these fog lights in The Retrofit Store, they are brighter than stock and little bit wither than the signature LEDs.
Hate to tell you, but white bulbs are pretty ****** fog lights, if you intend on using "fog" lights for their epononymous, intended purpose.
Not to mention the fact that a fog light needs to have a very sharp cutoff so that it shines "under" the fog.
