Change out differential and transfer case fluids
Ben Myton
Tacoma WA
Anyone have the actual shop manual and could send me a snap shot of the instructions?? They wouldn't show that to me...
Thank you in advance!
Ryan
I have no idea what bandwidth this guy has on his file share, but this is one of the only complete workshop manuals I've seen online...
http://www.mediafire.com/file/a9strl6pfp4vvzf/D4_Workshop_Manual.pdf
Page 540/5528 covers this.
Olli Rita
Florida
2006 LR3 rear and front differential recommendation is pretty much every oil change. Free breathing so fill it until it spills (I use Royal Purple), comes out "well used" dark and smelly with shavings every time.... Did my Wife's LR4 at 23000, clear and nice totally different than my 209000 mile LR3 (LR4 has front Royal Purple, rear LR "special"). Your mileage may vary.
Pfunk951
'03 would be the Disco II, it might be similar but you should check on the other forum..:biggrin:
Mike
jpjp
Florida
Is this what people have purchased? I have the locking rear diff.
Has anyone had to change out the bearings and do an overhaul of the front or rear diff?
http://www.roverparts.com/Parts/DTCM100B
This is the list and the combined cost is $239.95
Genuine Differential Fluid: Rear Electronic Locking Differential 1 Liter Castrol Bot 720 2 $95.90
Differential / Axle Oil 75W90R GL5 Fluid 1 Quart 2 $43.90
Transmission Fill Plug 1 $11.95
Fill Plug Rear Diff 2 $5.90
Drain Plug Differential Rear 1 $3.95
Plug Transfer Case Drain/Fill 2 $9.90
Washer Drain/Fill Plug Transfer Case 2 $1.90
Genuine Transfer Case Fluid 1 Liter / 1.05 Quart By Land Rover 2 $79.90
Fugi Snow
Santa Fe, NM
The front diff is the biggest pain the ass compared to the others because you need to take the front skid plate off.
The drain hole is front and center once the plate is removed.
I found the same gunk on the front drain plug.
To get the best access to the fill hole I removed the drivers front wheel. It made it much easier to fill the diff.
It took just under 1 litter.
I'm about to do differential and transfer case oil change. Thanks for this documentation but I have one... You removed the driver front wheel to replace the front differential oil? Is this correct? Thanks
Quijote
Metro Boston
Thanks for reviving this thread. This fall I'll be at 6 years and ~38k miles. I think I will tackle the diffs & transfer case then.
I didn't take my wheel off. If you've got a good injector tool and flexible hose, there's no need to.
TeriM
