Hello from Long Island
Long Islander
lONG iLAND
Good afternoon everyone.
I became a new owner of a 15 LR4 with 96k on her.
1 owner and she was dealership taken care of the whole time.
Anything I should know immediately? Im reading about the compressor challenges, where they go at 130k? Any other kwerks I should be aware of.
I want to welcome myself to the group and thanks for reading.
Bethesda, Maryland, USA
Do you have or can you access the service records? That will answer a lot of questions about what to focus on including scheduled maintenance of items that are getting long in the tooth at that mileage. But first, congrats and welcome!
Long Islander
lONG iLAND
I got a copy, removed the owners name for privacy and posted below:
Long Islander
lONG iLAND
Vehicle History Report
03/17/2020 04:19 PM
2015 LAND ROVER LR4
Repair Order: 49748
Mileage: 94206
Total: $181.00 Open Date: 12/09/2019
Closed Date: 12/12/2019
Advisor : Gregory Jordan Fuhri. Owner:
Service: BK55 Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Type:
Technician:
Comeback: N Labor: $419.95
Parts: $452.10
Misc: $0.00 Complaint: Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Cause: Correction: Service: MA52 Blade, Wiper (Rear)- Replace Type:
Technician:
Comeback: N Labor: $33.99
Parts: $26.84
Misc: $0.00 Complaint: Blade, Wiper (Rear)- Replace Cause: Correction: Service: CS10 Thermostat - Replace Type:
Technician:
Comeback: N Labor: $343.88
Parts: $175.40
Misc: $0.00
Complaint: Thermostat - Replace Cause: Correction:
Service: CEL C/S THE CHECK ENGINE LIGHT IS ON HAS SINCE GONE OFF PLEASE COMPLETE ONE HOUR CHECK OVER AND AND PROVIDE PROGRESS REPORT
Type: CC
Technician: Daniel Smith
Comeback: N Labor: $169.95
Parts: $0.00
Misc: $0.00 Complaint: C/S THE CHECK ENGINE LIGHT IS ON HAS SINCE GONE OFF PLEASE COMPLETE ONE HOUR CHECK OVER AND AND PROVIDE PROGRESS REPORT
Cause: FAULT FOR LOW PRESSURE FUEL PUMP Correction: DECLINED REPAIRS Service: CFS CUSTOMER STATES THE VEHICLE IS DUE FOR SERVICE CHECK HISTORY AND ADVISE Type: CC
Comeback: N. Labor: $0.00
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE VEHICLE IS DUE FOR SERVICE CHECK HISTORY AND ADVISE Cause: Correction: Service: B112A096000 Service - 96,000 Miles
Technician:
Comeback: N Labor: $1,313.64
Parts: $917.45
Misc: $0.00
Complaint: Service - 96,000 Miles Cause: Correction; Service: FU13 Pump, Fuel - Replace Type:
Technician:
Comeback: N Labor: $431.88
Parts: $658.15
Misc: $0.00 Complaint: Pump, Fuel - Replace Cause: Correction:
Type:
Service: MA65 Blades, Wiper (Front) - Replace Type:
Technician:
Parts: $85.38
Misc: $0.00 Complaint: Blades, Wiper (Front) - Replace Cause: Correction: Service: 10 customer declined repairs Type: CC
Comeback: N Labor: $0.00
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE BRAKE PAD LIGHT IS ON Cause: THE REAR BRAKE PADS ARE 2MM AND NEED TO BE REPLACED Correction: DECLINED THE REAR BRAKES
Service: 99LRZMPI PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT.
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: PERFORMED MPI Service: FS32 Arm, Control (Front Lower) - Replace Type:
Technician:
Comeback: N Labor: $273.95
Parts: $929.27
Misc: $0.00 Complaint: Arm, Control (Front Lower) - Replace Cause: Correction: Service: None c/s the low coolant light is on Type: CC
Parts: $0.00
Misc: $0.00 Complaint: c/s the low coolant light is on Cause: THE THERMOSTAT ASSEMBLY IS LEAKING Correction: DECLINED REPAIRS Service: MA79 Alignment Front and Rear - Check and Adjust
Technician:
Comeback: N Labor: $249.95
Parts: $0.00
Misc: $0.00 Complaint: Alignment Front and Rear - Check and Adjust Cause: Correction: Service: 15LRZ **LOANER VEHICLES** Type: CC
Parts: $0.00
Misc: $0.00
Complaint: **LOANER VEHICLES** Cause:
Correction: Repair Order: 47163
Mileage: 81909
Total: $181.00 Open Date: 06/17/2019
Closed Date: 06/18/2019
Advisor: Carlos D'Oleo. Owner:
Service: 15LRZ ENTERPRISE RENTAL**LOANER VEHICLES** Type: IRE
Technician: Matthew T Moritz
Parts: $0.00
Misc: $0.00 Complaint: ENTERPRISE RENTAL**LOANER VEHICLES**
Type:
Type:
Cause: CUSTOMER REQ SERVICE LOANER Correction: PROVIDED AN ENTERPRISE RENTAL
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: MPI Service: 46LRZLR3 COMPLETE FOUR WHEEL ALIGNMENT AND SET VEHICLE BACK TO FACTORY SPECIFICATIONS Type:
Technician:
Parts: $0.00
Misc: ($50.00) Complaint: COMPLETE FOUR WHEEL ALIGNMENT AND SET VEHICLE BACK TO FACTORY SPECIFICATIONS Cause: Correction: Service: lower control arms are loose
Technician:
Comeback: N Labor: $791.95
Parts: $0.00
Misc: $0.00
Complaint: lower control arms are loose Cause: Correction: replace both front lower control arm assemblies
Service: 61LRZ CUSTOMER STATES THERE IS A BURNNING RUBBER SMELL COMING FROM THE VEHICLE. PLEASE CHECK AND ADVISE.
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THERE IS A BURNNING RUBBER SMELL COMING FROM THE VEHICLE. PLEASE CHECK AND ADVISE,
Cause:
Correction: removed melted debris from exhaust system Repair Order: 46414
Mileage: 78368
Total: $0.00 Open Date: 04/29/2019
Closed Date: 04/30/2019,
Service: 15LRZ L-333**LOANER VEHICLES** Type: IRE
Technician: John Stover
Comeback: N Labor: $5.00
Parts: $0.00
Long Islander
lONG iLAND
Misc: $0.00 Complaint: L-333**LOANER VEHICLES** Cause: CUSTOMER REQ SERVICE LOANER Correction: PROVIDED SERVICE LOANER L-333
Service: 40LRZ2010BRAKES CUSTOMER STATES THAT BRAKES WORN ERROR MESSAGE IS SHOWING. PLEASE CHECK AND ADVISE.
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THAT BRAKES WORN ERROR MESSAGE IS SHOWING. PLEASE CHECK AND ADVISE.
Cause:
Correction: inspected brakes and brake sensors, found left front sensor damaged, appears to be from road debris. replaced sensor and cleared faults.
Type: CC
Parts: $0.00
Cause:
Correction: MPI Repair Order: 45949
Mileage: 76408
Total: $3,371.00 Open Date: 03/29/2019
Closed Date: 03/29/2019
Advisor: Carlos D'Oleo Owner:
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: 76409 MPI Service: 46LRZTIREPROMO4 MOUNT AND ROAD FORCE BALANCE 4 TIRES255/55/19 111v conti Type: CC
Comeback: N Labor: $199.95
Parts: $998.00
Misc: $0.00 Complaint: MOUNT AND ROAD FORCE BALANCE 4 TIRES255/55/19 111v conti Cause: tires worn on edges Correction: REPLACED 4 TIRES Service: 46LRZ **TIRES/ALIGNMENT ** Type: CC
Comeback; N. Labor: $0.00
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES TPMS LIGHT ON FLAGS R/F TIRE **TIRES/ALIGNMENT ** Cause: Correction: set all tire pressures Service: BR20 Pads and Rotors, Brake (Front) Replace Type: CPM
Comeback: N Labor: $359.95
Parts: $0.00
Misc: $0.00 Complaint: Pads and Rotors, Brake (Front) Replace Cause: Correction: REPLACED FRONT PADS AND ROTORS Service: 40LRZ BRAKE CONCERN Type: CC
Parts: $706.20
Misc: $0.00 Complaint: CUSTOMER STATES THE BRAKES ARE NOISYBRAKE CONCERN Cause: Correction: front brakes Omm, see added lines Service: 15LRZ **LOANER VEHICLES** Type: CC
Parts: $0.00
Misc: $0.00 Complaint: E-PRISE **LOANER VEHICLES** Cause: Correction: PROVIDED LOANER Service: B112A080000 Service - 80,000 Miles Type: CC
Comeback: N Labor: $662.84
Parts: $394.50
Misc: $0.00 Complaint: Service - 80,000 Miles Cause: Correction: PERFORMED SOK SERVICE Service: 46LRZLR3 COMPLETE FOUR WHEEL ALIGNMENT AND SET VEHICLE BACK TO FACTORY SPECIFICATIONS Type: CC
Comeback: N
Labor: $249.95
Parts: $0.00
Misc: $0.00 Complaint: COMPLETE FOUR WHEEL ALIGNMENT AND SET VEHICLE BACK TO FACTORY SPECIFICATIONS Cause:
Correction: PERFORMED 4 WHEEL ALIGNMENT Repair Order: 43328
Mileage: 68234
Total: $3,004.00 Open Date: 10/13/2018
Closed Date: 10/18/2018
Type: CC
Technician: Michael D Fulton
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: 68241 MPI Service: 10LRZ CUSTOMER STATES THE ECO STOP/START DOES NOT WORK. PLEASE CHECK AND ADVISE. Type: CC
Comeback: N Labor: $155.88
Parts: $327.55
Misc: $0.00 Complaint: CUSTOMER STATES THE ECO STOP/START DOES NOT WORK. PLEASE CHECK AND ADVISE. Cause: FAILED MAIN VEHICLE BATTERY.
Correction: REPLACED MAIN VEHICLE BATTERY. RESET BATTERY MONITOR, ROAD TESTED AND CONFIRMED OPERATION.
Service: BK55 Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Type: CPM
Parts: $434.56
Misc: $0.00 Complaint: Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Cause: Correction: REMOVED AND REPLACED REAR BRAKE PADS AND ROTORS. Service: 01 CAR WASH Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CAR WASH Cause: Correction: 68241 PERFORMED CAR WASH Service: 20LRZ CUSTOMER STATES THE COOLANT ALERT IS ON. PLEASE CHECK AND ADVISE. Type: CC
Comeback: N Labor: $1,326.95
Parts: $412.76
Misc: $0.00 Complaint: CUSTOMER STATES THE COOLANT ALERT IS ON. PLEASE CHECK AND ADVISE. Cause: REAR COOLANT CROSSOVER TUBE LEAKING.
Correction: REMOVED ENGINE SUPERCHARGER, REMOVED AND REPLACED REAR COOLANT CROSSOVER TUBE, RE-ASSEMBLED AND FILLED WITH COOLANT. PRESSURE TESTED AND CHECKED FOR LEAKS. ROAD TESTED, NO LEAKS.
Service: 15LRZ L-300**LOANER VEHICLES** Type: IRE
Comeback: N Labor: $25.00
Parts: $0.00
Misc: $0.00 Complaint: L-300**LOANER VEHICLES** Cause: CUSTOMER REQ SERVICE LOANER
Correction: PROVIDED SERVICE LOANER L-300 Repair Order: 42937
Mileage: 67105
Total: $1,012.00 Open Date: 09/19/2018
Closed Date: 09/24/2018
Service: 99LRZMPI PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT,
wwwLWARE
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: 67107 MPI Service: APPRAISAL PERFORMED APPRAISAL Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORMED APPRAISAL Cause: CUSTOMER HAS REQUESTED TO HAVE THEIR VEHICLE APPRAISED Correction: PERFORMED AN APPRAISAL
Service: 10LRZ CUSTOMER STATES THE VEHICLE WILL NOT COME OUT OF DRIVE. THERE IS A GEAR BOX FAULT ALERT ON THE DASH. PLEASE CHECK AND ADVISE.
Type: CC
Comeback: N. Labor: $393.88
Parts: $555.51
Misc: $0.00 Complaint: CUSTOMER STATES THE VEHICLE WILL NOT COME OUT OF DRIVE. THERE IS A GEAR BOX FAULT ALERT ON THE DASH. PLEASE CHECK AND ADVISE.
Cause: INTERNAL FAULT WITHIN GEAR SHIFT SELECTOR.
Correction: REMOVED AND REPLACED GEAR SELECTOR. PROGRAMMED TO VEHICLE. TESTED MULTIPLE TIMES, NO FAULTS.
Technician:
Parts: $440.04
Misc: $0.00 Complaint: Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Cause: Correction: Service: 15LRZ ENTERPRISE RENTAL**LOANER VEHICLES** Type: CC
Parts: $0.00
Misc: $0.00 Complaint: ENTERPRISE RENTAL **LOANER VEHICLES** Cause: CUSTOMER REQ SERVICE LOANER
Correction: PROVIDED AN ENTERPRISE RENTAL Repair Order: 42766
Mileage: 66810
Total: $166.00 Closed Date: 09/13/2018
Comeback; N Labor: $0.00
Parts: $0.00
Misc: $0.00 Complaint: ENTERPRISE RENTAL**LOANER VEHICLES** Cause: Correction: Service: 40LRZ BRAKE CONCERN Type:
Technician:
Comeback: N. Labor: $441.95
Parts: $0.00
Misc: $0.00 Complaint: REAR BRAKE PADS AND ROTORS. Cause: Correction:
Type: CC
Parts: $0.00
Misc: $0.00
Cause: FAULTS WITHIN GEAR SHIFT MODULE.
Correction: PERFORMED POWER AND GROUND CHECKS TO GEAR SHIFT MODULE. FOUND AND PERFORMED UPDATES TO GSM AND TCM. UPON CHECK SIGNS OF SOMETHING POSSIBLY SPILLED ON GEAR SHIFT MODULE, COULD CAUSE INTERNAL SHORT OR FAULURE. OPERATING AS DESIGNED NOW. CUSTOMER DECLINED REPAIRS AT THIS TIME.
Type: CC
Parts: $0.00
Correction: MPI Repair Order: 41354
Mileage: 60996
Total: $2,269.00 Open Date: 06/07/2018
Long Islander
lONG iLAND
Closed Date: 06/15/2018
Service: 10LRZ CUSTOMER STATES THE ECO STOP/START IS NOT WORKING. PLEASE CHECK AND ADVISE. Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE ECO STOP/START IS NOT WORKING. PLEASE CHECK AND ADVISE. Cause:
Correction: FAULT MAY BE DUE TO ENGINE FAULT. REPAIRED ENGINE FAULTS AND ROAD TESTED VEHICLE ECO STOPPED.
Service: 85LRZ CUSTOMER STATES THE KEY FOB BATTERIES ARE LOW. Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE KEY FOB BATTERIES ARE LOW. Cause: Correction: 61005 REPLACED KEY FOB BATTERY WITH NEW Service: 189004 ENGINE MANAGMENT - SYSTEM DIAGNOSIS - INCLUDES CONFIGURATION OF NEW ECU Type: W
Comeback: N Labor: $39.72
Parts: $694.76
Misc: $0.00 Complaint: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON PLEASE COMPLETE ONE HOUR CHECK OVER AND AND PROVIDE PROGRESS REPORT
Cause: FAULTY VALVE COVER PCV VALE
Correction: FOUND FAULTS IN SYSTEM P2189-00 System Too Lean at Idle Bank 2,P2187-00 System Too Lean at Idle Bank 1. SMOMKE TESTED ENGINE FOUND BANK ONÉ VAVLE COVER LEAKING FROM PCV VALVE. REMOVED SUPER CHARGER AND RELATED PARTS AS PER WORKSHOP MANUAL. REMOVED AND REPLACED BANK ONE VALE COVER. RE-ASSEMBLED AND CLEARED FAULTS, RESET ENGINE ADAPTAIONS AND ROAD TESTED.
Service: 15LRZ L-245**LOANER VEHICLES** Type: IRE
Comeback: N Labor: $35.00
Parts: $0.00
Misc: $0.00 Complaint: L-245**LOANER VEHICLES** Cause: CUSTOMER REQ SERVICE LOANER Correction: PROVIDED SERVICE LOANER L-245 Service: B112A064000 Service - 64,000 Miles Type: CC
Comeback: N Labor: $519.05
Parts: $389.77
Misc: $0.00 Complaint: Service - 64,000 Miles Cause: Correction: PERFORMED 64K SERVICE. Service: CEL COMPLETED SECONDARY DIAGNOSES AND REPLACED FUEL PUMP
Type: CC
Comeback: N Labor: $313.88
Parts: $640.70
Misc: $0.00 Complaint: AFTER REPAIRS THE CHECK ENGINE LIGHT REAPPEARED. Cause:
Correction: 61005 WAEK/FAULTY IN TANK FUEL PUMP. FOUND FAULT IN SYSTEM PO089-64 FUEL PUMP REGULATION PERFORMANCE. FOUND FUEL PUMP OUTPUT SIGNAL TO PCM OUT OF RANGE. REMOVED FUEL TANK. REMOVED AND REPLACED FUEL PUMP AND FLANGE ASSEMBLY. CLEARED FAULTS AND PERFORMED ROAD TEST. NO FAULTS.
Service: 122944 COVER - CAMSHAFT/ROCKER OR CYLINDER HEAD - RH/REAR - RENEW Type: W
Comeback: N Labor: $794.40
Parts: $0.00
Misc: $0.00 Complaint: COVER - CAMSHAFT/ROCKER OR CYLINDER HEAD - RH/REAR - RENEW Cause: Correction: Service: 46LRZTIREPROMO2 MOUNT AND ROAD FORCE BALANCE 2 TIRES Type: CC
Comeback: N Labor: $99.95
Parts: $454.00
Misc: $0.00 Complaint: MOUNT AND ROAD FORCE BALANCE 2 TIRES Cause: Correction: INSTALLED 2 TIRES MOUNTED AND BALANCED.
Service: E COMPLETED SECONDARY DIAGNOSES ON CHECK ENGINE LIGHT FOUND FULE PUMP TO HAVE FAILED REPLACED FUEL PUMP AND COMPLEYED EXTENDED ROAD TEST
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: MPI Service: 20LRZ CUSTOMER STATES THE COOLANT ALERT IS ON. PLEASE CHECK AND ADVISE. Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE COOLANT ALERT IS ON. PLEASE CHECK AND ADVISE. Cause: . Correction: TOPPED OFF COOLANT Service: MA65 Blades, Wiper (Front) - Replace Type: CC
Parts: $84.52
Correction: REPLACED WIPERS. Repair Order: 38592
Mileage: 52379
Total: $500.00 Open Date: 11/24/2017
Closed Date: 11/24/2017
Type: CC
Technician: Darrin Hinton
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION, DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: Service: M2 MOUNT AND ROAD FORCE BALANCE 2 NEW TIRES Type: CC
Parts: $454.00
Misc: $0.00
Complaint: MOUNT AND ROAD FORCE BALANCE 2 NEW TIRES Cause:
Correction: Repair Order: 37367
Mileage: 47450
Total: $759,00 Open Date: 08/22/2017
Closed Date: 08/25/2017
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: PERFORMED COMPLIMENTARY INSPECTION Service: 861510 BATTERY START STOP RENEW Type: W
Comeback: N Labor: $51.20
Parts: $297.66
Misc: $0.00 Complaint: CUSTOMER STATES INSTALL START/STOP SECONDARY BATTREY Cause: BAD START STOP BATTERY Correction: 47451 TESTED BATTERY, FAILED. HHE500-4001JPA-81E077 REPLACED WITH NEW BATTERY Service: 861520 BATTERY - CONDITION - CHECK Type: W
Comeback: N Labor: $12.80
Parts: $0.00
Misc: $0.00 Complaint: BATTERY - CONDITION - CHECK Cause: Correction: Service: 15LRZ **LOANER VEHICLES** Type: IRE
Comeback: N Labor: $15.00
Parts: $0.00
Misc: $0.00 Complaint: L-180**LOANER VEHICLES** Cause: CUSTOMER REQ SERVICE LOANER Correction: PROVIDED SERVICE LOANER L-180 Service: B112A048000 Service - 48,000 Miles Type: CC
Comeback: N Labor: $461.31
Parts: $0.00
Misc: $0.00 Complaint: Service - 48,000 Miles Cause:
Correction: DID 48,000 MILE SERVICE Repair Order: 36831
Mileage: 44920
Total: $1,971.00 Open Date: 07/12/2017
Closed Date: 07/14/2017
Technician: Anthony Bruschetta
Parts: $689.64
Misc: $0.00 Complaint: Pads and Rotors, Brake (Front) Replace Cause; Correction: 44930 REPLACE FRONT BRAKE PADS AND BRAKE ROTORS
Service: 99LRZMPI PERFORM COMPLIMENTARY INSPECTION, DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT,
Type: CC
Parts: $0.00
Cause: Correction: 44930 SEE BELOW Service: EE10 Battery - Replace Type: CC
Parts: $0.00
Misc: $0.00 Complaint: Battery - Replace Cause: Correction: BATTERY NOT IN STOCK HAD TO BE ORDERED
Service: 50LRZ CUSTOMER STATES THE ECO START STOP WARNING IS ON AND THE CEL COMES ON AS WELL ENGINE ELECTRICAL
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES THE ECO START STOP WARNING IS ON AND THE CEL COMES ON AS WELL ENGINE ELECTRICAL
Technician: Anthony Bruschetta Comeback: N Labor: $0.00
Parts: $0.00
Misc: $0.00 Complaint: **LOANER VEHICLES** Cause: Correction: Service: BK55 Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Type: CPM
Parts: $435.53
Misc: $0.00 Complaint: Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Cause: Correction: REPLACE REAR BRAKE PADS AND BRAKE ROTORS Service: 61LRZ EXTERIOR TRIM Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER REQUESTS ESTIMATE FOR BODYWORK EXTERIOR TRIM Cause: Correction: Service: 51LRZ CUSTOMER STATES THE 3RD BRAKE LIGHT FLEW OFF ON THE HIWAY *BODY ELEC DIAG Type: ISP
Parts: $92.62
Misc: $0.00 Complaint: CUSTOMER STATES THE 3RD BRAKE LIGHT FLEW OFF ON THE HIWAY *BODY ELEC DIAG Cause:
Correction: OUTSIDE REPAIR Repair Order: 33924
Mileage: 31916
Total: $890.00 Open Date: 11/03/2016
Closed Date: 11/08/2016
Service: 46LRZTIREPROMO1 MOUNT AND ROAD FORCE BALANCE 1 NEW TIRE Type: CC
Technician: Matt Sonzogni
Comeback: N Labor: $49.95
Parts: $236.00
Misc: $0.00 Complaint: CHECK TIRES. Cause: NORMAL WEAR. Correction: CONTINENTAL 4X4 CONTACT 255/55R19. Service: B112A032000 Service - 32,000 Miles
Type: CC
Comeback: N Labor: $393.98
Parts: $0.00
Misc: $0.00 Complaint: Service - 32,000 Miles Cause: Correction: Service: 15LRZ **LOANER VEHICLES** Type: W
Parts: $0.00
Misc: $0.00 Complaint: **LOANER VEHICLES** L-101 Cause: LOANER L-101 Correction: Service: LC LOANER VEHICLE Type: IRE
Parts: $0.00
Misc: $0.00 Complaint: LOANER VEHICLE Cause: Correction:
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: Service: None CUSTOMER STATES TIRE PRESSURE LIGHT IS ON. CHECK AND ADVISE. Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER STATES TIRE PRESSURE LIGHT WAS ON. ADDED SOME AIR AND IT SEEMS OK BUT PLEASE CHECK OVER ANYWAYS
Cause:
Correction: Repair Order: 32798
Mileage: 26901
Total: $2,412.00 Open Date: 07/27/2016
Closed Date: 07/29/2016
Comeback: N Labor: $10.00
Parts: $0.00
Misc: $0.00 Complaint: LOANER VEHICLE Cause: Correction: Service: CHECK DAMAGE TO CHMSL.
Technician:
Parts: $0.00
Misc: $0.00 Complaint: CHECK DAMAGE TO CHMSL. Cause: CRACK IN CHMSL LENS. ASSEMBLY WILL NEED TO BE REPLACED. Correction: Service: 61LRZ REPLACED VALVE STEM CAP Type: CC
Parts: $0.00
Misc: $0.00 Complaint: CUSTOMER REQUESTS REPLACING MISSING VALVE STEM RIGHT FRONT WHEEL EXTERIOR TRIM Cause:
Type:
Correction: 26901 REPLACED VALVE CAP Service: BR20 Pads and Rotors, Brake (Front) Replace Type: CPM
Comeback: N Labor: $275.00
Parts: $656.51
Misc: $0.00 Complaint: Pads and Rotors, Brake (Front) Replace Cause: Correction: Service: BK55 Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Type: CPM
Comeback: N Labor: $299.95
Parts: $408.14
Misc: $0.00 Complaint: Pads/Shoes and Rotors/Drums, Brake (Rear) - Replace Cause: Correction: Service: 15LRZ L-113**LOANER VEHICLES** Type: W
Parts: $0.00
Misc: $0.00 Complaint: L-113**LOANER VEHICLES** Cause: . Correction: Service: 61LRZ REPLACED HIGH MOUNT REAR STOP LIGHT Type: CC
Parts: $166.35
Misc: $0.00 Complaint: CUSTOMER STATES THE HI MOUNT STOP LIGHT IS BROKEN EXTERIOR TRIM Cause: Correction:
Service: 40LRZ *BRAKE DIAG CUSTOMER STATES BRAKE PAD LIGHT IS ILLUMINATED. PLEASE CHECK AND ADVISE
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: *BRAKE DIAG CUSTOMER STATES BRAKE PAD LIGHT IS ILLUMINATED. PLEASE CHECK AND ADVISE Cause: Correction: Service: 46LRZ REPLACED 1 TIRE Type: CC
Comeback: N Labor: $49.00
Parts: $242.00
Misc: $0.00 Complaint: CHECK TIRES FOR WEAR. Cause: RIGHT REAR TIRE WORN DUE TO LOW AIR PRESSURE, Correction: CONTINENTAL 4X4 CONTACT 255/55R19.
Type: CC
Parts: $0.00
Correction: Repair Order: 32237 .
Mileage: 23475
Total: $321,00 Open Date: 06/07/2016
Closed Date: 06/08/2016
Service: None C/S THE R/F TIRE WENT FLAT Type: CC
Technician: Matthew Fuente
Comeback: N
--ALL.www.wwwwwwwwwwwwwwwwww
w wwwwwwwww www.wwww
WWW.
Labor: $49.00
Parts: $244.00
Misc: $0.00 Complaint: C/S THE R/F TIRE WENT FLAT Cause:
Correction: Repair Order: 30804.
Mileage: 17691
Total: $53.00 Open Date: 02/11/2016
Closed Date: 02/12/2016
Service: 99LRZMPI PERFORM COMPLIMENTARY INSPECTION, DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT.
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: PERFORMED MPI Service: 051010 check trim with feeler gauge no further action Type: W
Comeback: N Labor: $12.50
Parts: $0.00
Misc: $0.00 Complaint: AS PER DDW PERFORM Q561 WINDSHIELD FINISHER COMMING LOOSE ** RECALLS** Cause: Correction: 17692 PERFORMED SERVICE ACTION Q561 OPTA Service: 46LRZTIREPROMO1 MOUNT AND ROAD FORCE BALANCE 1 NEW TIRE Type: CC
Comeback: N Labor: $49.90
Parts: $0.00
Misc: $0.00 Complaint: MOUNT AND ROAD FORCE BALANCE 1 NEW TIRE Cause: Correction: Service: None HAS A FLAT TIRE. CAR IS BEING TOWED IN. NEEDS REPLACEMENT. CHECK AND ADVISE. Type: W
Parts: $204.00
Misc: $0.00 Complaint: HAS A FLAT TIRE. CAR IS BEING TOWED IN. NEEDS REPLACEMENT. CHECK AND ADVISE. Cause: .
Correction: REPLACED TIRE HAD HOLE ON SIDE WALL OF TIRE PASSANGER FRONT R/F DOT#-AFP6N1XN-2215 Repair Order: 30291
Mileage: 15602
Total: $0.00 Open Date: 12/23/2015
Closed Date: 12/23/2015
Comeback: N Labor: $5,00
Parts: $0.00
Type: CC
Parts: $0.00
Misc: $0.00 Complaint: PERFORM COMPLIMENTARY INSPECTION. DOES NOT INCLUDE FRAME CHECK OR CAR FAX REPORT. Cause: Correction: PERFORMED MPI Service: 15LRZ **LOANER VEHICLES** Type: W
Parts: $0.00
Misc: $0.00
Complaint: **LOANER VEHICLES** Cause: LOANER L-60 Correction: Service: 101016 COMPLETED 16K SERVICE Type: W
Comeback: N Labor: $212.50
Parts: $186.63
Misc: $0.00 Complaint: C/S THE VEHICLE IS DUE FOR SERVICE PLEASE COMPLETE 16000 MILE SERVICE Cause: COMP 16K SERVICE Correction: 15603 COMPLETED 16K SERVICE
Service: 869064 INFORMATION SYSTEMS SATELLITE NAVIGATION/ RADIO AND CD) - SYSTEM DIAGNOSIS - INCLUDES CONFIGURATION OF NEW ECU
Type: W
Parts: $0.00
Misc: $0.00 Complaint: C/S THE NAVI SCREEN ONE TIME WAS FLASHING ON AND OFF WITH SILVER AND BLACK LINES
Cause: NO FAULTS CODES PRESENT AND TOUCH SCREEN IS WORING PROPERLY AT THIS TIME. THERE IS A SOFTWARE UPDATE AVAILABLE.
Correction: 15603 UPDATED THE TOUCH SCREEN CONTROL MODULE SOFWTARE Service: 129013 TUNE - DOWNLOAD - ENGINE MANAGEMENT ECU Type: W
Parts: $0.00
Misc: $0.00 Complaint: AS PER DDW PERFORM SERVICE ACTION Q514 Service Action: Oxygen (02) Sensors CONFIGURE PCM 129013 OPT B/C .20
Cause: CHECK ENGINE LIGHT SERVICE ACTION OPT B
Correction: PERFORMED SERVICE ACTION Q514 OPTION B. UPDATED ECM SOFTWARE Repair Order: 28016
Mileage: 4552
Total: $0.00 Open Date: 06/03/2015
Closed Date: 06/04/2015
Service: 709003 ANTI-LOCK BRAKING SYSTEM - SYSTEM DIAGNOSIS - INCLUDES CONFIGURATION OF NEW ECU Type: W
Technician: Aaron Lioe
Comeback: N Labor: $37.50
Parts: $0.00
Misc: $0.00 Complaint: PERFORM P062** RECALLS** Cause: . Correction: 4553 PERFORMED P062 OPTION B Service: 129013 TUNE - DOWNLOAD - ENGINE MANAGEMENT ECU Type: W
Parts: $0.00
Misc: $0.00 Complaint: PERFORM Q485** RECALLS** Cause: . Correction: 4553 PERFORM Q485 OPTION B
Type: CC
Parts: $0.00
Correction: Repair Order: 26566
Mileage: 10
Total: $0.00 Open Date: 01/20/2015
Closed Date: 01/29/2015
Advisor : Steve Cronin Owner: LAND ROVER PRINCETON ****
Service: 861501 BATTERY(S) - EACH - RENEW Type: W
Comeback: N
Labor: $25.00
Parts: $196.64
Misc: $0.00 Complaint: AS PER SALES CHECK BATTERYENGINE ELECTRICAL Cause: .
Correction: 10 BATTERY OVERCHARGED DUE TO LAND ROVER BATTERY TENDER. LEAKED OUT OVERHEATED REMOVED AND REPLACED BATTERY. Repair Order: 26354
Mileage: 3
Total: $0.00 Open Date: 01/02/2015
Closed Date: 01/06/2015
Service: 75LRZLR4 LR4 PDI Type: W
Comeback: N Labor: $137.50
Parts: $0.00
Misc: $0.00 Complaint: LR4 PDI Cause: . Correction: 3 PERFORM PRE DELIVERY INSPECTION PERFORMED PRE DELIVERY INSPECTION
The good news is that this does appear to be a very comprehensive set of dealer service records from original delivery to the time you purchased it. Some work was declined, I noticed, so either it was deferred maintenance or done elsewhere.
The bad news is that it is a lot of info to sift through visually. I recommend you get it all in a text file and do some keyword searches on it to see if particular repairs/service were completed. Here are some quick thoughts on terms to search. Others can add to this:
timing chain
timing chain guide
timing chain tensioner
water pump
crossover
lower control arms
LCA
fuel pump
injectors
spark plug
battery [saw several mentions of this]
MAF
throttle body
oil [troubled by the fact that this term doesn't seem to appear a single time in the service history]
Actually I found that it is possible to use my browser's Find function to search for keywords right here in the thread. That's how I found that "oil" never appears once...
777AIA
Just get a code reader and check for faults. Change all the fluids and the differential. Drive it for a while and feel out any kinks. Check back in with the forum...
