LR5 18” rims hit rear brake caliper and control arm
Nechaken
Is that a picture of the rear caliper?
Looking at the tuffant site, it seems to indicate that brake calipers with "5000/c" and "4999/c" will fit without modification.
https://www.tuffantusa.com/discovery5
different wheel maker, but there's only so much they can do with offset and such...
Wondering if yours maybe had a larger caliper...
I got them to work. I had to grind 1/16 off the peak of the rear caliper.
2017 D5 HSE Lux TD6 USA
gmfain
I am not sure. Mine was so close, it scratched the paint, but not the wheel base metal. But I knew with heating and cooling I had to give it at least 1/16 of clearance.
I did all the research your doing. Tuffant and all. I don't really know why mine barely touched.
flyingdog
seattle
Sorry for the delayed response.
265/60R18 KM3 BFG
No problem Gmfain. Thanks for the reply. I ended up ordering the 265/60R18 A/T KO2's.I'm excited to try them out. No one seems to have them in stock so I have to wait 5 more weeks :(
Nechaken
Just curious, if you have any idea if you could get 265/65/18 on a discovery 5 without any modding? Not a huge number of people adding wheels/tires yet, but as it gets older, I'm sure many more will. I know lucky8 has put 33" tires on there, but who knows what they did to get it to work.
Have a D4 with that tire size, but the D5 looks are growing on me, and the tech sure would be nice.
gmfain
Try Summit Racing
gmfain
I'm afraid they will rub some, that 1/2" wider and 1 inch tall, on 18"wheels.
Prolly have to use lift rods from LK8
flyingdog
seattle
Hello Gmfain,
Finally got my tires and 18"compo's together. Very happy with the combo.BFG ALL TERRAIN T/A KO2
LT265 /60 R18.
ar077
Las Vegas, NV
You could easily install larger tires. I have 285/50-20 Nitto Terra Grappler G2s on 20" x 9.5" wheels (including the spare) with no lift, no spacers, and no clearance problems. Comparing your tires to mine at https://www.wheel-size.com/calc/?wh...-18X7.5ET40&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm shows that you have .62" more sidewall height (and greater air-down capability). Get some rock sliders on that beautiful D5 if you plan on tackling serious trails.
flyingdog
seattle
Rock Sliders would be nice..
