Add 3rd Row Seating to LR4 2010
Emily Stone
Hello, New to this club as of Saturday and I’m very excited!
My LR4 came from Canada. 2010. 100k. Not an HSE and has got a super old in dash system. There’s a lot I want to do but right now looking to see if anyone has put in the 3rd row seating?
Do I have to get 2010 model parts, or would the 2011 work too? Or any other year?
Do you have any tips? Thanks
Are you sure you have a LR4?. IIRC all LR4s were three row. Perhaps early build 2010? A picture or two would be good.
Bethesda, Maryland, USA
I just checked an Edmunds review and even in 2016 the base LR4 came standard with 5 seats. I can't imagine that they sold many of them but it stands to reason that the base model in earlier model years had that same seating capacity. Rare!
Michael Gain
Clarksville, TN
I'm sure, depending where you are located, someone who wants to ditch the weight of the third row would be willing to meet up and swap parts with you. If I remember right, there are quite a few parts needed for the swap.
Quijote
Metro Boston
When ordering my car I do recall that HSE added the 3rd row. Naturally, HSE LUX had it as well. I just don't think people would custom-order their LR4 in the very base trim, and dealers (who order nearly all the LR4's) probably wouldn't either.
I have never seen a two row LR4 up here in Canuckistan but I suppose they could exist. . There are some 5 seater LR3s running around . (SEs)
How is the floor cavity handled when retrofitting those seats back there on a base model? Is it there under some type of removable rigid flooring?
Michael Gain
Clarksville, TN
Yes. I looked into the conversion once. There is a flat rigid floor that has underfloor storage, the side finishers are different to fit the required brackets to hold the rigid floor and remove the latching mechanism for the bottom cushions.
I loved having the seats removed, but missed the flat platform. I was motivated enough to reinstall the third row, but too lazy to build my own solution. I am also seriously considering the luggage partition. One side for gear and one side for the dog. Wouldn't be able to fit that part without a flat floor
Michael Gain
Clarksville, TN
Forgot to mention that the 5-seater also has the lower head rests. The ones that sink almost level to the top of the seat. Looked into those too to improve rearward visibility. I couldn't confirm if the "leg" spacing and diameter was the same.
LB Bill
California
Ouch! Sounds, (and looks) like a complicated and potentially very expensive undertaking. Not just the seats, but side panels, headliner...and then there's the little matter of 'compliant' seat belts! The stock are mechanically retractable and mounted to the roof posts under the vertical panels. And even though I have little use for mine, generally speaking, the third row really enhances the value of the vehicle. You might be able to find what you need out of 'salvage'? Depending on how important that third row is to you, much as I hate to say it, most LR4's available out there have them. Maybe reconsider before you get too far into this one??
Nico3dd
