Does anyone knows of a video on how to replace the LR4 HIDs.
Georgemera1
I found videos showing on how to replace the HID of a Range Rover headlights but nothing on the LR4, can someone help me on this?
Thanks in advance.
George,
PoorLifeDecisions
Norcal
I think this is the only one on Youtube:
The mechanism to fit the bulbs is not very well designed and it's possible to install the bulb mis-aligned. That's because the bulb fits up against these fanned out prongs that have give. So, make sure you take your time and check it over before and after putting in the new bulb. I happened to mis-align one of my bulbs and locked it in place. This caused the beam pattern to turn into a shallow V shape and for awhile I thought I might have broke something until I went back in to re-install the bulb.
Have you gotten your headlight removed from the car?
If so, it's super easy to take inside and work on. I had a HID bulb shatter and had to clean it out of my housing.
