Cabin Air Filter
ar077
Las Vegas, NV
I haven't seen any threads or posts on how to change the Discovery 5 (L462) cabin air filter. Anyone have info? Thanks!
Rover Range
Texas
Located behind the glove box.
Turn ignition on.
Select " recirc" on AC panel.
Open glove box.
Push down on the two outer tabs at rear of glove box, to fully open.
Remove cabin filter.
Depending on the year model, there may be an additional panel covering the filter.
quirozson
Denver, CO
Turn ignition on.
Open glove box.
I just changed mine on a 2019 and the airflow indicator on the actual filter was facing down. Was that correct? The black plastic case for the filter had an arrow facing up. TIA
Rover Range
Texas
Filter arrow correct for airflow.
Plastic case arrow for orientation (up) in the case.
