V8 Coolant Manifold / Crossover & Maintenance Parts List
sfdaytona
Ashburn, Va
Thank you guys for that. I actually found that the o-ring at the water pump side of that oil cooler tube was messed up. I replaced it today and pressurized the mostly empty system to 13psi for 15 min, no leaks. Refilled, bled system and am back on the road! Thanks for the inputs!!
Nick
Rover Range
Texas
Is there an easy way to pressurize the system or do you need a special tool?
You do need a pressure tester and the correct adapter to fit the coolant reservoir.
