Misfire cylinder 8
Rover Range
Texas
Could it be valve clearance. Recently did head gaskets, could be wrong sized tappets?
Yes.
If all they did was head gaskets, there's no need to mess with the tappets.
If they fell out and were put back in the wrong spots, then you would have issues.
tvanstee
Saskatoon
Yes.
They were spilled so not placed in the original positions. Might be the source of my misery. I'll have to open up the valve cover to check clearances.
Rover Range
Texas
Bummer.
Exhaust cam clearance is 0.25 mm ± 0.02
Inlet cam clearances doesn't have to be checked, they have hydraulic adjusters.
tvanstee
Saskatoon
Pulled valve cover to measure valve lash and looks like we may be onto something here. Tappets were marked when removed from the engine but seem to have been put in front to back instead of back to front.
Cylinder 2 tappets have clearance of 0.5 mm while Cylinder 8 which is misfiring has no clearance. Cylinders 4 & 6 are within spec
I guess this means a bit of a teardown to repair. Will have to set up some weekend to do this job.
Rover Range
Texas
Awesome.
The exhaust cam will have to be removed.
tvanstee
Saskatoon
Pulled exhaust cam off yesterday and swapped tappets between cylinder 2 & 8. Valve lash was then back in spec and once I fired her up the misfire was gone. Seems like valve lash was my problem the whole time. This one seems solved. Thanks everyone for your help!
tflint2112
