power steering fluid
FFNPMcD
I have been noticing that I am having to refill my power steering fluid at a regular basis now..
Best I can determing the fluid seems to be leaking from the hydrolic pump..
Is this an indicator that the pump may be going bad... or could it just be an indicator that I just need to do some basic hose replacement?
Anybody have any experience with this?
Thanks,
Neill
Also what kinds of problems can I create with little to no power steering fluid?
samroverguy
Rovers are notorious for leaking oil and powersteering fluid. It is the norm. Check where the hoses attach to the powersteering box and try to determine if it is just a hose leak. Might have to change the whole powersteering box, which is doable and not terribly expensive.
joey
First thing I would check this the hose clamps coming off where you fill it, they are very cheap and tend to leak bad. Personally I replaced the hoses and the clamps almost 3 years ago and haven't leaked any fluid since.
FFNPMcD
Hey Joey..
Are the hoses generic enough I can pick them up at a local aout parts store..
or do you order through will or nathan?
Thanks
Neill
joey
Kind of generic... you need to make sure they are oil resistant or the fluid will eat it up.
FFNPMcD
Can't find anybody round here carrying them... being told it's a dealer only product..
Did get my hands on some new hsed clamps... I'll give them a go and hope that fixes the problem...
Thanks
joey
I just bought 4 feet of high end oil resistant hose from Napa, and cut and made my own. around $5 IIRC
wolf
Thanks,
Neill
I went the real quick and cheap route because past experience taught me, what the heck - it works (as I also had some seepage of steering fluid down at the seals in the actual steering box)! i.e., get yourself a bottle of Lucas Oil's Steering Fluid and, voila, the seepage at the seals stops (don't forget to tighten clamps too). I don't work for Lucas Oils - so this is not an ad - their stuff simply works (and I have tried nearly everything out there - often with great dissappointment and crappy results).
By the way, just an extra here - most of those 'power-boost' additives, Octane Boosts, Upper Cylinder lubes, etc. don't do much, Lucas' works somewhat but its not outstanding - however CD2 (based out of Chicago) has an amazing product that really gave an extra boost to these lumbering V8's (especially an old one like mine) and, of course, now I can't get it up here in the Great White North anymore. But if any of you folks can still get that south of the border - do yourself and your engine a favor - and stock up!
