I only wish that it was smart enough to wait if there is still a door open. Too many times, my kid is still getting out of the back when it does this.
Every time I turn the truck off and get out I hear a swoosh of air that sounds like its coming from the driver side rear suspension. Not sure if its a leak or just normall process.
Thanks
I beleve it is normal. Do you ever get a msg from your computer about the compressor?
The brain will tell you if the compressor is running to much.
That's not normal, is it? As long as any of the side doors are open the car should freeze any suspension adjustments, until the doors are shut ...
What year are your LR3s? My vehicle self levels with the doors open, has done this from day 1. Other owners reported the same, but perhaps it is a 2005 thing.The passenger doors should stop the self leveling, until they are closed, at least they do in my truck..
Door Open Functionality
If one or more of the vehicle doors are opened during a height change when the vehicle is stationary, the air suspension control module will restrict further height change. The door open signal is transmitted by the CJB on the high speed CAN bus and received by the air suspension control module. This keeps the vehicle level to the set height when a door opens to allow for changes in loading conditions.
A hardwired door status signal is also transmitted from the CJB to the air suspension control module. This signal provides door status information when the high speed CAN bus is off, i.e.; during periodic re-levelling.
The lamp on the air suspension switch for the target mode height will remain illuminated and the raising or lowering lamp will flash.
If all of the doors are closed within 90 seconds, the height change will resume. If the 90 second period is exceeded and all of the doors are not closed, the height change will be cancelled. The mode lamps showing the previously selected height and the target height will be illuminated. The mode height change can be reselected by operating the switch, however, if the vehicle is driven at speed of more than 5 mph (8 km/h) the control module will continue to raise or lower the vehicle to the target mode height.
