Suspension Fault When Parked on Incline
Longtrail
Ann Arbor
I literally went through all my valves, everything, trying to chase this issue... I flashed the firmware once the GAP tool arrived and it was like a switch; the code went away and so far didn't come back (it's been 16 months)... I hope you have the same issue and resolution but defer to those who have more knowledge than I do. Good luck.
M32H32IS
Texas
Appreciate the insight, I plan to clean the desiccant and exhaust then I’ll flash the firmware as you mentioned.
Longtrail
Ann Arbor
I suggest figuring out what type of compressor you have (in my post I have an AMK and show pictures of it - this can help you identify what you have); then in the GAP tool you can identify what firmware you have. If there's a mismatch between the two (AMK physical compressor and say Hitachi compressor in the GAP tool) then flash the firmware... Only do this if there's a mismatch.
tflint2112
