I checked for spark by removing plug lead.....I have some tool that allows you to ground one end and adjust the gap to visually identify spark.
I only checked cylinders 1 - 4 ( 2 on each side) and saw nothing.
However, when the problem originally occured...at the gas station....I checked for spark on cylinder 1 first and had nothing. Then, began to check for spark on cylinder 2 ....at first there was no spark ( car would not start) Then the rover started and I was able to see a spark. So, I shut off the engine, put the plug lead back on and drove home.
I did notice when the plug lead was not on, and the vehicle started it was idling rough. Which leads me to believe that it's not just one individual cylinder causeing the problem. There is no spark at all.
Hope this is enough info...I'm just not used to working on this 03, my last one was a 95 Disco and was much easier to work on.
Thanks again
Ben
