W
wsy
My 1996 Disco I is developing a starting problem. Sometimes it starts, sometimes it doesn't. The engine spins just fine, (I even get oil pressure!); it feels like it's ALMOST ready to run, but it often doesn't quite kick in.
Diagnostics so far. Spark seems good ( AAAIIIEEEESHUTITOFF!!!! ) . Slight smell of gas out of the tailpipe when not starting. I replaced the plugs and plug wires with OEM from Rovers North; no change. Cleaned the K&N air filter; no change. If I just turn the key to the third click I can hear the fuel pump buzz away (however, the fuel pump does seem to sound considerably noisier than it did when I bought the car new ten years ago. (130Kmiles on it). I can hear the fuel pump as being slightly louder than the engine exhaust sound when I stand at the back of the truck with the engine running. (is there a way to test the fuel pump?) The diagnostic system display under the passenger seat says "everything is just fine".
The only pertinent things have been changed on the truck are both oxygen sensors have been changed and the exhaust system aft of the catalyst Y-pipe has been changed over to a stainless from Rovers North (twice - first rusted out, but RN got me a new one for free). Replaced the distributor cap and rotor too. Battery is fine; engine spins over no problem. Everything else on the truck is pretty much as it came from the factory (original coil, original fuel pump, original MAF).
This no-start happens mostly/only when the truck hasn't been run for a few days. If it's only been a few hours, then it rarely has any problem.
Clues? Suggestions?
Clues? Suggestions?
