1996 Disco oil
Burl
I am putting my Discovery 1 diesel in to the mechanic to change all oils in the motor ,auto trans ,diffs and anywhere else there is some .
I told the mechanic I would us Q8 5-30 full synthetic but he says don't as it wont build oil pressure and will burn oil and to use 15-40 -advice please
Depending on your mileage and how good you have been on keeping up with the services, here is a list of what you better plan on doing to get the most from your truck.
If you have any questions, send me your number and I'll call you.
Major Service for High Miler
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic ATF fluid
1 bottle of Lucas P/S stop leak
1 bottle Lucas Tranny Stop Leak
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
1 new fuel filter
Hoses and belts, as necessary
Front and rear wheel bearings and all seals for wheel bearings and swivels if necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive, change the filter if necessary
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Repack or replace the 4 wheel bearings
Service the swivel balls, reseal, refill and adjust the pre-load
Replace the fuel filter
Inspect and replace all hoses, brake, coolant and cooler lines as necessary
__________________
Burl
Mike thank you for that comprehensive advice,i will follow it and do it bit by bit.
My truck has done 176000 km and the last owner who wasn't the first owner changed oil every 10k.
My original question about which oil can you advise please 5-30 or 15-40 ?the mechanic also advised against a engine flush with fear of releasing crap into and around the motor.
I am in New Zealand otherwise Id give you a bell.cheers
If using regular oil, change it every 3000 miles, synthetic can go to 5000 miles.
5/30 or 10/30 for winter use and 15/40 to 20/50 for summers.
