2004 D2 turn signal problem
jasile
So I have a 2004 D2 with 111K miles.
All my interior and exterior lights are working EXCEPT the front right turn signal. The right rear turn signal and right side marker lights flash but the front doesnt. On the dash the green arrow blinks fast like the bulb is out.
I checked the turn signal bulb and verified that the bulb is good. The connections on the bulb socket are clean and look new. I checked the fuses; all good. I checked the ground behind the drivers side kick panel; looks factory new. I checked the relay (R2) in the fuse box under the steering wheel but cant tell if it is bad. If the relay were bad the rear and side marker lights wouldnt flash, correct? So is there a different ground for just the right turn signal that I havent found yet?
Any advice?
