2015 autobiography lwb
Dlee61
Dc
I have a new used just purchased and now the rear windows won’t roll don’t front will work rear will not is there a reset or known issue with the rear windows on this model please help service department a month behind
Sounds like you have a Range Rover, not an LR4. And your explanation is pretty short on facts.
That said, maybe it's just a reset you need?
jlglr4
Northern California
When you say the rear windows won’t roll down, do you mean using the drivers switch or using any switch? In other words, do they work if you are using the rear door window switches? If not, first thing to check would be the fuses.
