3 warning lights on
LR_none
The ABS, Hill Descent, and Traction Control amber lights come on after putting in drive and moving a few hundred yards. This is accompanied by the 3 chimes. The fuses look good, not sure what else it could be since I'm new to the LR game. It is a '99 LR II Disco. Any advice is appreciated.
You have posted the same question on at least 4 forums. In the time it took to do that, you could have done a search and found out what is going on.
If you can't even do any leg work, how do you expect to learn and maybe repair your Disco?
LR_none
I did a search but it helped to know what to search (3 amigos). Thanks for your help. Also, now that I know the same folks hang out on all the forums, I can just stick with one.
