94 discovery : rear diff leaking
94discovery
my local mechanic seems hesitant to fix my leaking rear differential.
is it a difficult ?
are there any how to guides on replacing the seals?
thanks
jeff danoff
Where exactly is it leaking from, the pinion seal the cover plate or from a wheel bearing?
How mechanical are you?
94discovery
not mechanical and i dont know the exact area of the leak...i will have to ask
thanks!
How long have you had it and when was the last time you had a major service done on it?
94discovery
it now has 250,000 miles i bought it with 75,000 miles.
i replaced the whole rear axle with a used one , probably 8 years ago.
i have the differential service at jiffy lube several times but not the last 3 yrs.
so no major service on differential.
i am on a silly mission to get some leaks fixed.
recent diagnosis;
Front engine crankshaft seal, engine oil pan gasket, front differential, rear differential and transfer case are all leaking
parts ordered:
to fix cranshaft seal
done:
oil pan gasket replaced
Replace rear differential upper control arm and ball joint assembly with
good used parts.
thanks!
94discovery
you were right about the leaks ..replaced the front and rear pinion seals. also replced 2 valve cover gaskets, transfer case seal and mount, power steering hose,suction hose and lines.
thanks!
gutlesswonder
If the oil pan hasn't ever been removed, it almost never leaks. It's the last item of business because any other sneaky oil leak can look like an oil pan gasket to a careless eye. Just food for thought.
Vintage99
