lsawicki
- Joined
- Jun 3, 2007
- Posts
- 64
- Reaction score
- 0
A common problem on Range Rover Classics is an annoying tendency to stall when you come to a stop after a long run. Kevan Wiser repports his procedure for fixing this periodically recurring problem.
1) Be certain the flame trap isn't blocked--remove it and check the "mesh ***" It just unscrews from the top-front of the PS valve cover.
2) Check the T-piece that connects the vacuum hoses going to the plenum--it's the obvious one central-front behind the distributor.
3) Clean the stepper-motor plunger and seat. this is easy to do is usually what corrects the problem for Kevan. He uses "brake cleaner" and a toothbrush to clean the plunger assembly making sure to clean the head that has to mate w/ the seat. Then, he uses a rag dipped in brake cleaner to clean the seat itself. He has read that others have used a bit of white grease to lube the plunger, but he always just gives it a shot of what ever WD40 - like substance is handy. For more on the care and feeding of this pesky and temperamental component, see the section on the idle air bypass valve/stepper motor above.
I found this on Range Rover remedies, and here is what I (think) I need to do:
Since I'm getting the Code 44, I'll replace the left bank oxygen sensor. Problem is, is the left while facing the front of the vehicle or left from inside of the vehicle?
As far as the idle problem, I will try the solution I found above, but I don't know where exactly the flame trap is, and I'm having trouble figuring out where the stepper motor plunger and seat are. Hence, I ordered a workshop manual on Cd, but until then, I would really appreciate any directions to the locations of the parts, because I'm a newbie and don't want to screw anything up...
