97 disco a/c
trdurkin
Hello,
I'am new to this forum. My 97 Disco. ,4.0 gems , when i run my a/c , the driverside gets cold, but the other side stays a little cooler(not hot). Need some ideas.
Thanks
trdurkin
tommy33
Low R-134. My 97 has same symptom when low on AC gas. Charge it up with 134 and use a pressure gauge.
Also make sure to run both the front and rear ACs on high when you charge up the system.
Good Luck.
trdurkin
Thanks tommy33, how much r-134a should the low be? and what should the high be at? Mine shows low=40 and high = 250 .
thanks
trdurkin
vegas99d1
Being that our trucks have dual climate control, sounds like you have a blend door issue. Never a bad idea to check your AC system anyway, but please use a set of professional gauges, not the kind from Autozone/Checkers!
tflint2112
