99 disco codes
evansjoem
P1300, and 3 other misfire codes. Has brand new 8mm magnacores, and new plugs. Ran for 2 weeks no problems. What's the issue?
evansjoem
Coil was changed 20k ago. 02 sensors 10k ago. Maf still stock, 100's of other add on's. Installed new winch today
evansjoem
10k superwinch $275 Amazon
evansjoem
Could someone help me with codes? I did put 89 octane in this morning.
aldoabastta
Colorado
Did you figure it out?
Start off with the basics, Spark, Fuel, Compression. Starting off with Spark, check to see if your coils are working.
Buy a spark tester if you can ($5-8 see pic), easy do it yourself Tool to see if the Coils are working.
ALSO! Your wires may be jumping spark to the engine! Causing a no spark to plug and/or sporadic idle. Best way to test it is look under the hood at the wires at night to see if the spark is jumping around. (YOU SHOULD NOT SEE A SPARK) Discos have the crappy design of having the wires come from the back. And thin Spark Wires don't help.
evansjoem
No I cleared the code and tightened clamp around opposite end of pcv valve. Been a few days with nothing so we will see
