Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Wish I could help, but haven't had much chance to work on or even see an 85 model Rover anything... the only issue is the 2.5 petrol is a small engine.
the good news about the 2.5 petrol engine is that you can take it out and put the 3.5 rover v8 into the hole it leaves. but you can also drop the 2.5 turbo diesel from the 90 series into your 85. the petrol engine you have at the moment would be bad on fuel consumption about 12 to 20 miles to the imperial gallon eg 160 fl/ozs this can be improved a small bit approx 5mpg by fitting a fairey over drive depending what model your vehicle is hope some of this helps.
i not able to tell you how much it is worth in the states, on the irish market it would fetch around 2000 euro. in uk market it would fetch 850-1300 sterling depending on condition. if your looking to sell it why dont you put it in the classifieds on this site??? you could also keep the vehicle and put a V8 into it
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
