Austin, Texas
Hey, I do not necessarily hear it rattle when I start the vehicle up. I do hear a ticking when the motor runs. I have assumed that has something to do with it all. Also, I do know even know how often I have done oil changes. It has been sporadic. I am planning on going to Rover Works and having them potentially replace the chains and coolant/water pipes, then get the vehicle on a strict maintenance schedule.
I would get a second opinion on the chain and tensioners.
Over the past 8 years my LR4 has cost $0.11/mile to maintain. That is anything that goes in or on it (parts, tires etc)​
That ticking sound when it's running is probably not the timing chains. These engines are noisy. The injectors make a racket. If there's a problem, it could be the fan clutch, but I'm not sure it's gotten cold enough in Austin to cause that to act up (most only make noise when it's pretty cold out and before the engine warms up).
Your 2013 should have the updated design on the timing chain guides. While still not perfect, they should last a lot longer than the earlier version, especially if the oil changes are kept to a reasonable 7k-mile frequency.
gsxr
Idaho
Did you ever confirm if it actually needs the timing chain job? Some dealers/shops are looking for work and may hear things that aren't there...
o_O
Disco2TrailEdit4
