Battery Change - Dealer/Indy versus big box store - Reset computer?
Johnnycakes
Cleveland
Hi
7 years in and I think I need a new battery.
I was thinking of just using Costco/Autozone etc, versus the dealer....but do the big box stores have the ability to reset my computer? Or is that only from the dealer or someone with a GAP tool?
Thanks!
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Our trucks are electrically very sensitive. The PWM charging system is very aggressive and it would behoove you to run a battery reset when replacing the battery to allow the charging profile to adapt to the new battery vs applying an older/degraded charging profile on a new battery. Will it still work without the battery reset, yes, but your new battery might have a shorter life span. To put things into perspective, I'm on my 4th battery. :rolleyes:
I've heard a few good things about the Autel AP200 and it can reset the battery. However, the Autel AP200 is no where near the GAP IID Tool capabilities. I would rank Autel AP200 as a budget code reader with added features to calibrate suspension, reset adaptation values, reset service intervals, battery reset, and a few other things. It's also under $70.
Never bothered with resetting for battery other than connecting neg and pos cables for about 10 minutes. Through one LR3 and one LR4 (since 2006) I have replaced 3 batteries (5 total including the originals) in 17 years. Current Battery is an Energizer AGM H8 and is approaching it's third year anniversary. I expect 5-6 years out of it.
