Bluetooth can not be found
Japper Rover
Hi All,
Just got my 2005 LR3 SE yesterday and love it. I can not however get my phone to find the Bluetooth connection from the vehicle. I am sure it has the Bluetooth module as previous owner had there iPhone paired with it. I have tried to find the signal using my blackberry storm and my iPhone 4 and no luck. Any suggestions.
Thanks,
JP
huelsmma
With the car on...select bluetooth from your phone settings, make sure its on and have it search for devices. It should find LAND ROVER. The pairing code is 2121 I can confirm the iphone 4 and blackberry bold work.
Japper Rover
Thanks for the reply. Tried what you suggested a few times, no luck. Bluetooth on the phone works because I have used it for other devices. I guess I will have to go to the dealer and get them to have a look.
nashvegas
Are there green/red buttons in the right side of steering wheel?
Are there green & red buttons on the RH side of the steering wheel? If not, you dont have bluetooth. Bluetooth was _not_ factory fit on any 2005 LR3 models, HSE or SE. Came in late 2005 on 2006 models. It is retrofittable though. Could just be its dead / unplugged. Let us know.
Thos
Bluetooth not working/working intermittently
Ill join in with my pennys worth: I had a retro-fit Bluetooth done on my 07 TDV8. Most of the time it does not work. When re-pairing the phone, My iPhone 5 cant even find the car. However if I place a call directly from the iphone or receive a call, then the system wakes up, only to throw me out telling me " No phone connected" whats wierd is that the system can sometimes work with the ignition on, only to stop imediately after starting the car. Finally, If I drive more than 2 hours, the phonesystem works fine. Any ideas? Oh, and the steering wheel buttons stopped working today. The wheel-heating works, but the red light is very dim and flickers. None of the other button lights or functions work except the horn. I have an intermittent Airbag warning light coming on too despite having the seat belt pre-tentioner changed. Sounds like an ECU has gone, but any tips would be very welcome! Thanks:)
Thos
Intermittent Bluetooth
Thanks for the suggestion! Im not familiar with the car (L322) so is this a spring for the actual clock at the bottom centre of the console??
Rubber Cow
Nope , good guess though...it's a part on the steering column that allows for electrical communication between the steering wheel electronics and the other parts of the car...also called a rotary coupler..
Thos
Steering wheel functions not working
Ahh! Thanks for enlightening me:)
I had also read that it might be the ignition-key barrel too. I cleaned and sprayed the key with WD-40 and left a thin film before inserting the key in the barrel and turning the car on to position two a couple of times. Started the car, and everything worked as it should. I have no idea if this really sorted the problem - or if the car decided to work again of its own accord. I wasnt about to spray the ignition lock directly though:)
kwlr3
Also try doing a hard reset; disconnect both battery cables and touch the two cables together (you will need something to bridge the gap as the cables are too short to reach each other, a long screw driver will work)
I have an '05 HSE (very early model) that was not fitted with the phone kit. I installed it myself and twice it got so "out of sync" for lack of a better term that it could not recognize the phone. The phone system just needed to be de and then re-powered. The first time I dis-connected all the modules and got it working. The next time, I just did the re-boot.
Follow all of the pairing instructions in the manual. FYI, mine pairs with the code 0000.
