CEL illuminated - multiple codes
John Higgins
San Diego, CA
Started the car and saw the CEL illuminated. Pulled the codes and got:
P0106 - Manifold Air Pressure (MAP) Barometric Pressure Sensor Electric Circuit Output Range and Performance Problem
P0133 - Oxygen Sensor Circuit Slow Response
P0850 - Park/Neutral Switch Input Circuit
U0402 - Invalid data received from TCM
B1A00 - ??
There doesn't appear to be anything in common here that would trigger all of these. (At least to my amateur eye). The CEL went out after a few ignition cycles but did reappear a few weeks later. That CEL also is now gone. I haven't cleared the codes so they're ready for the Dealer if I go that route. Curious if anyone can provide any insight. Car runs fine now and also when the CEL was illuminated.
Thanks!
John Higgins
San Diego, CA
Battery is relatively new (less than 12 months). I haven't checked the voltage, but I will. Thanks for the reply!
jlach993
Fresh Meadows Queens NY
I'm 95% sure it's an electrical issue. It's most likely a battery problem. Even though your battery is less than 12 months old to you, doesn't mean it's not way older. Maybe you have a dead cell, unless you have an AGM. Plus these rovers suck through batteries every 18-36 months. Opt for an H8 AGM battery if you haven't done so yet, but back to your CEL issue, it's definitely something voltage wise that's making the car throw random codes. I had it happen to me when my factory H7 acid battery was going after roughly a year when the car was brand new and i upgraded to an H8 AGM and that was the end of those random codes.
Azoo
Brampton Ontario
Definitely the battery/Charging sys with the above TCM code.
