Front passenger axle threads stripped by axle nut...looking for advice
TrinidadLR4
NE Washington DC
There is nothing particularly involving about replacing the front half shafts in this truck. There are a couple of videos on Youtube that show you how. A good one to follow is this guy doing it on an L322.
Lakeranger
West Texas
I had major issues using after market axles. They wouldn't stay seated and kept popping out. The axles use a split ring to seat into a groove in differential and I found that the OEM is a beefier axle and their split rings mates to the differential without popping out. Of course your damaged axle, if OEM, can be difficult to now pop out during removal.
Marco Pizzolo
ontario
Thanks Lakeranger.
I took a break from laying on the cold concrete in the garage for a bit, but appreciate the insight. I'm certainly not unwilling to buy OEM in order to ensure that the job is only done once. In the video i watched it looked like they used a small pry bar to pop out the half shaft from the differential. Is that what you did as well, or did you find a better approach?
Thanks again,
gvillalongo
